Slightly bent runner. :p
CCCT
Barrie/Sudbury/Muskoka
Canada
2007 Apex
2009 PhazerGT
Backing sled into garage last night this happened..it's supposed to be straight correct? (jk)
Anyways, planning on going out tomorrow so need to fix fast. Think I should bend back to straight-ish with my bench vice and reinstall?
I have dual runners on each ski and this was the inner clutch side runner.
forget it. got it straightened out as much as I could and its a little wonky, and likely wont line up for the studs to fit through the ski. New question: Am I fine to run with only 1 runner on the left ski (meaning will it make the steering "off") or should I run out tomorrow and just replace this single fubarred runner?
Replace both!!!!!
You can straighten and ride in a pinch, with hammer and vice have been able in past to get through the ski holes. I would replace as soon as you are able
Ok thanks . Maybe I'll I just reolace both tomorrow but that said no reason to replace all 4 if I don't need to right ?
correct. I would not run it without one even if it steers fine that bar serves two purposes one is steering the other is a wear bar to prevent the ski from getting ground down.
Picked up 2 new carbides this morning. Just going to put the 2 new ones on the inside of each ski and leave the 2 good older ones on the outsides. Should be good to go with that plan.
Now you have 1 spare!!
Yep.
I always overthink everything, but no issues with the 2 outside runners/carbides being different with the 2 insides right?... As long as it's symmetrical I assume.
Yep.
Correct, you just want matching pairs on the opposite side. Ex. 4-6-6-4
