Sly Dog Bogie Wheels
lornoh
Lake Orion, Michigan
Just got a set of new Sly Dog Bogie wheels and was looking for installation instructions. Thought it would be simple but noticed that with the two front outside wheels the bolt thread is different than stock. Is this just a simple swap of the wheels or is there more to it?
Thanks.
should of received bolt nut and spacer, the forward bogie install using nut spacer and bolt, the aft you must obtain a bolt that is 4" total lenght from yamaha, personally called kevin at port. i notified brian at slydog there was a problem, cause yamaha welded a nut on the 09's. noticed after looking at my 08 and talking to a friend who mounted them on a 06 that requires a nut on the back hope this helps
