JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Just bought a set of the slydog trails with the skis savers and was disappointed in the aggressiveness of them!! They like to push in the corners more then i want!! Does the skis saver have any effect on how well these skis carve or do i have to make some adjustments to the limiters??
Justin
Justin
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Did youshim the front and toe it in 1/8 inch. Maxdlx
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Have not done that!! Was told that these skis dont have to be shimmed but i will check to see! how high should the front of the wear bar be off the ground? What does the change in toe do for the handling?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I am running a 3/8 shim in the front and toed in 1/8 inch. This per scott bergstroms recomendation. Mine work great so far. Maxdlx
JROCK
- Oct 25, 2007
- Ottawa, Ontario
I will try that out!! what are you using for a shim if you dont have them sent from scott?
NJNYTRO
try a toilet shim- sounds stupid but works
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Maybe i will give scott a call and order a set if his triple points and get some shims!! thanks guys!!
