zr8000
- Dec 29, 2005
I had a dealer change exhaust donuts (copper) and Y pipes on 2007 Yamaha Attak.
The smoke starts shortly after it is running and from what I can tell, the smoke is rising from exhaust donut area. It will run for about 30 secs before I start seeing it. I shut it down because it is very hard to tell where exactly the smoke is rising from. It has a distinct smell so I'm sure it's not the standard exhaust smoke or steam.
Anyone experience this? Is there anything that has 'insulation' on it that might be touching the exhaust?
Sled ran fine before getting this done.
guardrail
If they used any wd-40 or penetrating oil to get the bolts loose, that's probably what you're seeing/smelling. I would just let it idle. it will clear up in a few minutes
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
X2, nothing to worry about.If they used any wd-40 or penetrating oil to get the bolts loose, that's probably what you're seeing/smelling. I would just let it idle. it will clear up in a few minutes
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
its just burning off some of the oils in the new products.
Grimm
Yup, just burning off... It will eventually subside
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
nothing in that area that could be getting hurt let it burn for 5-10 mins and if it dont stop then have a look maybe they left a rag in there a little smoke and funny smell is normal after exhaust work in my garage i will run the sled long enough for that to go away so you the consumer dont have the concerns that you have but im sure there is no problem.
zr8000
- Dec 29, 2005
Thanks for the confidence.
I did run it in the garage for a while more and seemed to be getting better.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
first good hard run down the trail and it will be gone.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I used never-sieze on the clamp bolts when I re-assmbled the exhaust after changing to copper donuts. After start up the smoke was unreal as the excess was burning off. I admit, there was a moment I began questioning my mechanical ability. lol. Once it ran for a bit it thinned out.
MS
MS
