80h4thephaze
On my sled there is snow coming up through the tunnel and cooling the pipe. But thats not the problem. The snow melts and runs down the tunnel and soaks my boots. Any suggestions on how to stop besides closing the tunnel?
Isthatahemi
80h4thephaze said:On my sled there is snow coming up through the tunnel and cooling the pipe. But thats not the problem. The snow melts and runs down the tunnel and soaks my boots. Any suggestions on how to stop besides closing the tunnel?
Is it a 2007 or 08? If it's and 07, Yamaha will under warranty supply panels to close off the tunnel.
Phazed-Coug
Yamaha will Close the hole, or just the tunnel side panels?
fletch83
they will just add the side panels, mine is getting them tomorrow under warranty, but i would recommend closing off the tunnel as well since there is so much ice build up under the tunnel, which adds alot of unwanted weight
Pat M
- Jan 4, 2007
- Pelham, NH Clarksville, NH
- www.xtreme-av.com
- 06 Nytro, 07 Phazer FX, 12 SkiDoo MXZ Sport, 14 SkiDoo MXZ
Save yourself the headache and just get some aluminum from Home Depot or Lowes and close that back hole uder the exhaust and then also the 2 holes along side the grab handle. That will definitely make your riding much more enjoyable. I am debating on closing off the front part of the tunnel as just closing the rear helped tremendously.
Bakemono
Yamaha sells side pannels that should at the very least limit the snow that gets on the running boards. They also claim that the panels strengthen the subframe.
The part number for the panels is:
Aluminum: SMA-8GCSK-00-AL
Black: SMA-8GCSK-00-BK
Blue: SMA-8GCSK-00-BL
The panels arent exactly cheap though, they list for $139.95.
yukonranger
re
The panels don't strengthen the subframe. They are just plastic that bolts to the tunnel but doesn't attach in any way to the subframe. However when you side panels are installed, they will also install a small brace which does strengthen the subframe a bit. however it is retardedly heavy.
cdsgraphic
Idaho Nytro
The side pannels are a joke. yamaha sent me some, I put them on and It didnt help at all. Now Im closing off the hole completely.
doogie
I closed both holes on my 07 FX and now, no more soggy boots...
80h4thephaze
ya i already put the plastic side panels on and i have yet to try them out. im still thinking about closing the tunnel.
cdsgraphic
if your mostly a trail rider, you'll be glad you closed at least the rear hole. the side panels help with the icing on the outside and running boards, but you'll be carrying an extra 20-30lbs of ice and snow on the inside after a good days riding if you leave it open.
RoicIND
Are they doing anything for us idiots who spent the $140 for the tunnel close off plates and the $175 for the 'un-necessary' (but required) cooling fan????
Nothing like having to pay for the items that correct design flaws of a brand new sled......
phaze5
ive spent some change fixin theyre mistakes to and im still payin hope it comes back fixed this time what part of ny do you live roic ind
