yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
So I installed all my bday gifts wifey bought me this morning blue snow flap, deluxe tunnel pack and aggressive snow tracker carbides!
I went for a run to test out the carbides and I gotta say i'm very impressed! Originally I was running woodie's slim jims last season and found they were good but still had a little push in the corners! I installed the snow trackers tightened my middle shock back up I and ran down the little road way beside my house and wow these things really grip well!!! It literally felt like I was rails!!
I had my wife try out my sled and now she wants a set!
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
Used semi aggressive last season they worked great but I had a little push . i think the aggressive set would be the answer!!
Did u get them from Yamaha ?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes my wife ordered them from Yamaha but royal distributing also has themDid u get them from Yamaha ?
I have run snow trackers for ever it's the only way to go imo , but I have never run them on tuner skis , is that what u have ?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No I have a 2014 with the regular skis! I ran them on my 2011 venture and loved them!I have run snow trackers for ever it's the only way to go imo , but I have never run them on tuner skis , is that what u have ?
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
for your cat i suggest shimming the front of the ski yamamarc....both mine and my buddies xr7000s wore the rear carbide off entirely first
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
how much are you shimmingfor your cat i suggest shimming the front of the ski yamamarc....both mine and my buddies xr7000s wore the rear carbide off entirely first
thanks
Marc
savageman69
- Apr 21, 2014
we used like 1mm tin...just about 1/2 inch strip front of the rubber...ends up being more then 1mm because it keeps the rubber from falling into the grooves. I found mine still wasnt right with snow trackers until we shimmed it. My dealer does it to their sleds they demo as well
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
thanks for the heads up i'll fix it up in the morning!!we used like 1mm tin...just about 1/2 inch strip front of the rubber...ends up being more then 1mm because it keeps the rubber from falling into the grooves. I found mine still wasnt right with snow trackers until we shimmed it. My dealer does it to their sleds they demo as well
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Are you shimming the SnowTrackers? If so, don't! Make sure your toe is set at 0 also!
savageman69
- Apr 21, 2014
thats not what i said....and the toe is not the issueAre you shimming the SnowTrackers? If so, don't! Make sure your toe is set at 0 also!
kviper
- Nov 7, 2003
- Oakfield WI
Your shimming under the rubber bumpers between the ski and the spindle right?
savageman69
- Apr 21, 2014
yes on cat skis
kviper
- Nov 7, 2003
- Oakfield WI
Are you loading the front or rear of the ski? The reason I ask is I have seen a few people loading the rear like Bergstrom does and it lifts the defuser out of the snow and defeats the whole design of the trackers.
