Snowtrackers ****HELP****
bigcatff7
Coldwater Ontario
Just installed a set of extreme Snowtrackers on my 08 Apex LTX 40TH and I have a lot of ski lift. I did notice I have a lot of slack in limiter strap and I'm not sure if that's correct? I should also say that I just bought this sled so I'm not sure if the previous owner has adjusted it.
I'm going to assume I need to adjust the front shocks but do I need more ski pressure or less?
Any suggestions from those who are running the Snowtrackers would great thanks in advance... :4STroke:
The Snowtrackers will help in producing ski lift due to the aggressiveness of the design.You could add more ski pressure to help stiffen the front end. A 13mm front sway bar will be your best bet to reduce the ski lift.
Like you I have a "new to me" Attak. I just put on Snowtrackers about 200 miles ago. My buddy has an Apex with Snowtrackers and the 13mm sway bar. The sway bar makes a big difference. On my hit list of mods to do yet.
Get the front arms as even as posible ! A little rougher in bumps but will corner alot better. The Apex will always corner a little flatter and better than the Attack ..
