YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
I found out you cant use the cam locking bearings used on cat and polaris track drive shaft. I went to lock down the bear and couldn't move the locking caller. you would have to machine the non drive side of the shaft to relieve the bearing. Plus the bearing fit isn't near as good as the yami bearing.
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
ThanksI found out you cant use the cam locking bearings used on cat and polaris track drive shaft. I went to lock down the bear and couldn't move the locking caller. you would have to machine the non drive side of the shaft to relieve the bearing. Plus the bearing fit isn't near as good as the yami bearing.
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Thanks for the info, I tried searching but none of this came up. Cheers
