spark plugs
tofast
NH
what are the best plugs for the 04 rc1 worrier and wear can I get them
10ek's pretty much every dealer has them, otherwise Port yamaha or Ulmer for sure
CR10EK Check out Ebay I got some pretty cheap there because "cheap" is what they're not!!
They're a little cooler and double the electrodes so you don't have to index the plugs!
Mighty said:
And you will pick up an honest 3 HP.
I'm not sure about 3hp but my Nytro felt different, as in goooood different!
I'm wondering if I should try them in my wifes Phazer?
RxThunder said:
Then 10ek's are different then what an 03 rx1 has from factory right? If so what is the benefit?
Stock plugs from the factory are CR9E. CR10EK have a separate electrode on either side of the tip. They are one range colder than the stock plugs.... hence easier to foul, although I've not heard of anybody doing so. Another alternative that I used to use in my 03 RX-1 was the CR9EIX. That's an iridium tipped plug that almost can't be fouled too. Both the CR10EK's and the CR9EIX's will run anywhere from double to triple the money of the stock plugs. In my opinion a case of the old "you get what you pay for".
X2
Ive been running the cr9ek plugs in the rx for 2 years. No problems and has the duel electrodes!
