rx1 cdi box
tofast
NH
i having problem with my top end on my o4 worrier it is cutting out on top I have plenty of fuel and my plugs are new . the plug caps are tight to . from 0 to 60 is perfect but when throttle is to the bar it cuts out. the RPMs jump from 10.5 to 10.8 i tried jetting and a electric fuel pump. I have the I am running apex cams and k and n filters with the stock horns and ported heads do you think it is the CDI box failing please help thanks
Have you tried to bypass the TORS (ThrottleOverRideSystem)?
I suspect you are getting a Rev Limiter signal. These engines are designed to run at 10,200 RPM
cutting out
what are you running for jetting. as i would think some were around 172.5 -180 would work for you the rev limeter should not even enter into it at this time as you are way below that rpm (11200) as i have been running mine over the top this year at 10800-10900 with out cuting out. so my guess would be to lean. to rich and it will just slow down . to lean and they tend to cut out at high rpm.(no fuel to burn)
