Speed sensor problems ????
saylavie
Elk Lake, Ont.
:o|When we went on our trip, I blew a bearing and it took out the speed sensor giving me a code #42 and at the same time it started to give me another code #84 throttle overide, what a pain to ride. Its not until I replaced the speed sensor that all the problems went away, we stopped at 3 Dealers and nobody ever heard of this, we checked everything and the throttle was all good. You can`t disconnect your override because your cooling system are interlinked with it, keep this in mind. Marc
Not true , just bypass the tors until you get a new sensor and the sled will run fine.
we had the same issue. replaced the bearing and bypassed the tors until the new speed sensor came in.
I own a 2006 venture RS and with these models if you disconnect the overide and you end up busting your cooling system for some reason(Ex:studs through cooling lines) the engine codes will not show this problem then you end up seizing your engine. If you disconnect it, don`t leave it out of commission to long. Just for info, Marc
Not true , tors is a different system.
Cooling is a different system.
T.O.R.S. has nothing to do with the cooling system. It is tied in with the CDI box. If you move the gas lever up or down like I did, you may experience T.O.R.S. codes and a lousy running machine.
i was with this guy when we went to 2 different yammi dealer,i asked the mechanic where the tors wire was,like on the rx1,2 green connectors,on the newer sleds,its different,he told us if we bypass the tors,it will throw codes,like a wire is not connected and we would lose coolant and oil light warnings in case of a problem,both dealers said the same thing
