tedgoesfast
Does anyone know if speed sensor is bad will it cause a throttle switch error code mine blew a bearing and damaged my sensor now it is acting up
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
Yep, happened to me and activated TORSDoes anyone know if speed sensor is bad will it cause a throttle switch error code mine blew a bearing and damaged my sensor now it is acting up
- Jun 28, 2004
- Clinton, Wi.
Yup, it sure will. Went through this with my Attak a few yrs. ago. Kept throwing a code and set off the TORS.
tedgoesfast
Thanks guys ecm must need to see speed when letting off throttle to meter fuel
tedgoesfast
Has anyone put a 1.5 ripsaw on a 121 apex is there enough clearance to stud it
apex55
I over greased the bearing one time and that also caused the tors to come on. To much grease got on the gear.
