Sled Dog
It looks like the speed sensor from an RX-1 to Apex is in fact the exact same as far as the eye can see even though they have different part numbers.
pat the rat
good to know
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
So does it work? Thats the million dollar question!
Sled Dog
Waiting for parts changing the gearing extroverts, sliders bearings and some wheels.
nb-attak
i have a used rx-1 speed sensor on my apex. works the same because it is the same.
Sled Dog
Well just waiting for the top 24 tooth gear and It will be back together. I decided to gear up from 21T top to 24T. I am wondering what kind of top end I should expect from gearing up. Not using this sled in the mountains so I might well gear up a bit. Drive shaft is back in with new bearings and Maverick 8 tooth extroverts. Skid is back in with new blue wheels and blue sliders greased all up with a fully clipped track. Still cant check the speedo sensor until I get the top gear and chaincase back together. I never kept track of which way the chain was in the case and I am wondering if it matters?
Sled Dog
Sasquatch said:So does it work? Thats the million dollar question!
Well I finally got it back together the top gear finally got here. Yes the speedometer works just fine. The little gear it reads to give you your speed is the same number for most of the sleds so it is no surprize that our speedometers are not really that accurate.
