Turboflash
- Mar 18, 2019
- Southern MN
FP - good to know. I usually shim at .030. Want to have a little wiggle room.Stage 4 on the race tune runs rich enough at stock FP to run with Q16. PEFI actually recommends Q over C. Have run Q many times on my own and customer sleds on stage 4 race without bumping FP. AFR's were always spot on. I do always drain Q and run pump fuel through afterwards. Make sure you are not locking the gate tight and leaving .018 - .020" clearance.
NIL8GM
- Sep 23, 2019
- Kars, ON
- turbo cat
.030" is good too!FP - good to know. I usually shim at .030. Want to have a little wiggle room.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Fp is supposed to be good to 500 hp correct?
Pefi recommends internals also cranking boost to these
Where will you be running this
My 998 is same setup but I have the turbo smart setup
93 grams in a adapt is alot
I’m running mid 40s finish on helix
NIL8GM
- Sep 23, 2019
- Kars, ON
- turbo cat
PEFI uses a 255lph pump in their kit. More than enough pump for anything the 998 block can handle. But yes the pump can support 500+hp. No internal upgrades are needed unless you are on a bigger turbo w/race fuel.Fp is supposed to be good to 500 hp correct?
Turboflash
- Mar 18, 2019
- Southern MN
Stock turbo is the limiting factor (governor). W wg shimmed to .030 it will only produce about 22-23 lbs (w header).PEFI uses a 255lph pump in their kit. More than enough pump for anything the 998 block can handle. But yes the pump can support 500+hp. No internal upgrades are needed unless you are on a bigger turbo w/race fuel.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Limiting factor very well maybe your injectors at 22-23 lbs there should be no issue . At 28-30 lbs on Q16 I’d be cautious
Turboflash
- Mar 18, 2019
- Southern MN
92 TeamFp is supposed to be good to 500 hp correct?
83-84 ADAPT
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
What are you running for weight on pump gas?FP - good to know. I usually shim at .030. Want to have a little wiggle room.
Turboflash
- Mar 18, 2019
- Southern MN
Pump Stage 4What are you running for weight on pump gas?
ADAPT about 74
