kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Doing the spindle bushings on an apex. Any tips on getting the new oilite bushings in?
06dukeGT
Pretty sure there's a sticky on front end bushing replacement on here! Looking to do mine this summer
kered
- Mar 22, 2014
- 09 Apex GT
How would I find that? I did see the one for the a arms but nothing that goes into the skis or spindle bushings.
Fairly straight ahead. Remove the old ones and tap the new ones in. Use a dead blow hammer or a block of wood on the bushing if they are stubborn.
What Steiner said!!!! I found it helpful to find something to support the ski if alone. My .02
kered
- Mar 22, 2014
- 09 Apex GT
Can they not be changed without taking the spindles off of the a arms? Just pull the ski off ?
I kept the spindle on the ski, just marked them to keep the alignment.
kered
- Mar 22, 2014
- 09 Apex GT
How did you mark them? Is there not a bushing on the bottom of the spindle?
I marked the location with a grease pencil so I could line up the splines when I reinstalled it.
kered
- Mar 22, 2014
- 09 Apex GT
So when you take the skis off the toe in has to be re-aligned?
Not if you mark it so it goes back in the original place.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
You might have to be a VIP member to see them, Don't know for sure.
kered said:How would I find that? I did see the one for the a arms but nothing that goes into the skis or spindle bushings.
kered
- Mar 22, 2014
- 09 Apex GT
see what? I guess you do have to be a vip member?
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
there is alignment marks on the spindle and spindle arm. remove the top black cap and you will see the marks.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
what jrock said. remove the black cap on the end of the spindle and you will see that there are aligment marks to get it back together . after i removed my sprindle i took the old bushings out and then i used a long threaded ready rod with flat washers and pushed the new ones in. took a few minutes each side.
