During my track change I 'misplaced?' the compression spring that goes in the small holes on the reverse gears. the part number is
90501-060A1-00. The dealer said the new number is 90501-06022-00.
Is there an aftermarket part i can use? Or some other option. No one around here has one in stock.
I am in International falls Minnesota and would travel today if someone has one.
dave_dj1
check the local hardware store , in their spring drawer, it doesn't look like anything all that special, maybe even out of a pen?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I'm not sure if it is the same spring but check with LazyBastard because one of his posts says that he is running without a reverse spring. Check his second post in this thread.
http://www.ty4stroke.com/viewtopic.php? ... rse+spring
Thanks. I pm'd him. I didn't notice a spring when I took it apart but I was having a few 'liquid wrenches' along the way.
Thanks again
Thanks again
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I ran my viper for 1400 miles without it, right up ill I traded it, no problems. A pen spring may just work
i'm a bit leary a pen spring might pop out causing some damage.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
post a wanted add. Over the years on both sites there has been chaincase failures, someone may just have one. Maxdlx
They cost under 2 bucks so they can't be much of a spring. My dealer is ordering me a few so next time I pull it aprat to change gears I'll put one in.
