ahicks said:<<<A heavier sway bar will help more by sucking up the inside ski as the outside compresses.>>>
I agree completely - but you have to allow the outside spring to compress. Increasing spring tension is counter- productive. The larger bar simply does not allow as much twist (body roll) prior to doing it's thing.
mbarryracing said:ahicks said:<<<A heavier sway bar will help more by sucking up the inside ski as the outside compresses.>>>
So it IS a trade off of softer bump absorbtion for less ski lift? I guess I ride more in bumpy NY rails than high speed flat corner trails.
