Yammybob
Gents I have a 2010 nytro XTX and am having a squeak issue from the A-Arm area when I drive on rough trails. Has anyone ever encountered this problem, or heard of someone who has? If so what is the solution?
Thks
Thks
Filks
I had a similar issue - seemed like it would only squeak once I had been riding for a bit and it was quite rough out like you mentioned. I tried the easy route and sprayed some WD40 around the pivot points on the spindle and I haven't heard it in a long time. WD obviously won't last forever, but it's quick and easy - might be worth a shot.
