markt111
has anyone had to replace their pivot arm due to wear? While pulling shocks for a rebuild and doing a good inspection I noticed the pivot arm has some metal slides that the track runs on, one of these slides is missing at this point, i am going to order a new one just never heard of this failure prior??
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Mine on my 16 Viper broke. Interestingly, my sons 14 has an extra set of gussets and same mileage and no sign of wear. I added them prior to installing it.
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
Mine were worn down to paper thin so I welded some steel in that area.
My sled does have over 20000 kms though
InRBigness
- Apr 10, 2014
mine both have about 18,000 kms as well. Gusset the side that isn't as well as mine broke at the weld.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I'm just getting ready to rebuild the suspension , and should fix this .has anyone had to replace their pivot arm due to wear? While pulling shocks for a rebuild and doing a good inspection I noticed the pivot arm has some metal slides that the track runs on, one of these slides is missing at this point, i am going to order a new one just never heard of this failure
Mine wore down in 16,000 klms. , possibly due to my shocks losing their charge twice in 3 years, Do you have pics of the welds ?Mine were worn down to paper thin so I welded some steel in that area.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
check out the one for the XC or XS chassy, every sled i replace the lower shock axle with the steel one from XC. once i changed my 2014 ltd to the QS3 shock... it busted the top shock mount and put shock and mount through track and into heat exchanger.... way to weak, thats why the XC is beefed up huge.
InRBigness
- Apr 10, 2014
You can see where the arm broke first on the upper left side of the picture. The other side let go once it twisted. My sons 14 has gussets on both sides at the bottom from the factory. I guess they tried to save some money and weight a few years later. I also had the front air shock fail 100 miles from home so I think that contributed to the wear I had on the track guides. I now run Elka stage 5's and as Max Rolph said, upgrade the cross shaft.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have (2) good used ltx front arms here with minimal wear .has anyone had to replace their pivot arm due to wear? While pulling shocks for a rebuild and doing a good inspection I noticed the pivot arm has some metal slides that the track runs on, one of these slides is missing at this point, i am going to order a new one just never heard of this failure prior??
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I replaced mine this past fall during regular maintenance.
Their is no pivot bushings on the lower pivot.
Shaft was worn and arm was worn. Always greased it but with miles on it things wear out.
Too bad they didn't put bushings in there for wear.
markt111
