Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Just purchased star suspension kit and new ice attack xt track, curious on feedback from the those that have done it, what's the transformation like on the trail
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
It takes bumps a lot better, no more back end hop. The track is a great compromise to picks. I also did oft steering relocate, Duce boy dual carbides, handles great through the trail, real fast.
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Good to know thanks, elaborate on your steering relocate kit? I put snow trackers on last year and they worked great, sometimes would grab in the corners causing high siding, Robert at Star said 128" would eliminate this allowing back end to swing a bit??
Yannie
- Jan 5, 2014
- Winnipeg
It moves the steering post forward 8 degrees I believe, allowing for less force to steer and a slight rise. It still has a slight roll to it but its a huge handling difference. I also added a clutch kit that lowers engagement and I found that to give better throttle control at lower speeds. I like to refer to it as the sling shot effect, when your going slow then accelerate and it whips you back from the high engagement.
Nytro Nasty
- Oct 17, 2014
- 2008 Yamaha FX Nytro 136, mountain fit vent kit, oft steering relocate, mountaintech skid plate, simmons flexi skiis with 6 dual runners, skinz front bumper, DDM Tuning HID lights, 55 watt ballasts with 4300k bulbs.
All done in one season.
That's is so far but much more on plate for this year!
Which clutch jut did you go with?
ccchris
I have the oft relocate and the star suspension with 128 ice attack, and it looks like we live in the same town.
If you want to take a look let me know.
Chris
Chris
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Hey same town, that's cool. I'm also interested in your SB clutch kit. If your up to it, I could certainly swing by before the snow flies. Cheers
Nytro Nasty
- Oct 17, 2014
I am curious what stage SB clutch kit did you get? Would love to see specs on all that comes in kit for $400. I will pay for the info if you can tell me what is all in kit exactly so maybe can piece one together separately?
Nytro Nasty
- Oct 17, 2014
I have a friend of my fathers who owns a Yamaha dealership for years and years. I asked him what his top service tech says I should get for a clutch kit? So may go that route also. I will post specs up when I get them. Thanks Tim.
Yannie
- Jan 5, 2014
- Winnipeg
Schmidt bros stage 2 kit. It came with a machined helix, spring, rollers and bolts to replace the outer rivet weights.
I have a SB stage 2 clutch kit if you want to buy it.....$100
shadow44
I'll buy if it's for saleI have a SB stage 2 clutch kit if you want to buy it.....$100
Tommyboy
- Oct 24, 2014
- Keswick, ON
- 2009 Nytro
Ok how does this work, I see you've got an ulmer kit, you made the switch were you not pleased with the SB kitI have a SB stage 2 clutch kit if you want to buy it.....$100
I was happy with it....I used it for 2 years. I recently upgraded to a supercharger and with that needed to change the clutching thats all.
Nytro Nasty
- Oct 17, 2014
Not sure how I missed this. If you still got it I would like to buy it. How many miles did you put on this kit? I sent you a pm with my number. Please call me. ThanksI have a SB stage 2 clutch kit if you want to buy it.....$100
