meklke
- Apr 19, 2005
- Cornell, WI
- SR Viper
I replaced the Steering Post Mounting Bracket Kit, after a complete failure of the bracket. After all was put back together my handle bars and skis are about 10 degrees out of alignment. What did a miss?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I have a friend that just did his Crosstour 7000 and when he was done he had to move the tie rods all the way out on one side and all the way in on the other side. He swears that he did it correctly. I did two Vipers and no issues at all what so ever. Strange.
meklke
- Apr 19, 2005
- Cornell, WI
- SR Viper
There is a tab that needs to be lined up. I have not found the patience to tear it all apart again.
meklke
- Apr 19, 2005
- Cornell, WI
- SR Viper
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
There are to of these bracket kits. One for 4-stroke and one for 2-stroke. I got the 2-stroke kit not knowing any better. The handle bar is way out of wack. To fix it you need the 2-stroke drag link which is a different length than the 4-stroke.
OR take it all apart and install the proper 4-stroke kit.
meklke
- Apr 19, 2005
- Cornell, WI
- SR Viper
Do you happen to know the part number for the 2-stroke drag link?There are to of these bracket kits. One for 4-stroke and one for 2-stroke. I got the 2-stroke kit not knowing any better. The handle bar is way out of wack. To fix it you need the 2-stroke drag link which is a different length than the 4-stroke.
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
You will need an Arctic Cat 1605-072 Drag Link, 112.6 mm. This is the 2-Stroke unit.
Your sled would have an Arctic Cat 1605-109 Drag Link, 106 mm. This is the 4-stroke unit.
The post mount at the bottom is in slightly different locations requiring different length drag links. I have no idea why they did this. The 2-stroke bracket and drag link works just fine and does not hit anything.
You and I will have the only sleds with 2-stroke steering.
- 17K
