Sorry to post so much today, but I would rather get this stuff done now....than when the riding is supposed to be going on.
I am replacing parts trying to get ride of the dreaded..."steering slop" in my 2009 Phazer RTX.
The original issue was that the handle bars moved side to side quite a bit without the skies moving.....you all know or have heard of that problem.
I installed the SBMS sloppy Steering fix and after a mod to their mod (drilled out bushings a little more....I was able to remove all the slop in the lower steering linkage that was there before I installed it.So, that is about half the problem solved.
The problem I have now is that there is still some slop in the "upper" steering linkage....mainly above the the Pivot Arm Assembly. It starts when I move the handlbars side to side and they move about an inch or so without anything in the lower steering moving. it appears to me that there may be some wear in this part:
8GC-23828-00-00 ROD, STEERING
I do have an OFT steering block yet to install, but I am wondering if that will really get rid of the rest of the slop?
Has anyone else had to replace this steering rod for wear?
Where is the rest of this side to side slop coming from?
Any advice or comments are appreciated. Thanks, guys.......
