stock attack hand warmers
myrodman
NEW BOSTON.ILLINOIS
06 attak
05 warrior
the hand warmers on my attack dont seam to get as warm as the older sleds is there anything that can be done to fix this? thanks :4STroke:
Yamaha had an update for this, new bars and a small harness. The updated bars have a different element that extends full length to cover the hooks too. I found a kit for 20 bucks. There is also a product called the Yamaheater. This combo works great.
Keep you 06 bars and get the Yamahheater. Great product and guy to work with.
I have 09 Ltx handwarmers sucked last year. I got the yamaheaters this year. Go with them,I wasted money buying new elements and new grips,nothing worked. Got the yamahaheaters for $175. I can tell the difference immediatley. All I need now is some snow to test them out.
If you're comfortable with wiring you can just rewire to series from parallel. I took the pins out of the connectors with a paper clip and moved the wires because I didn't want to cut/spice. The bars will be HOTT!! afterwards you will never need any setting over 50%. You should have an unused hot and ground lead coming from the main harness when you get done. There was also a harness sub-lead that accomplished the same thing not sure if it is still available.
Yamaheaters, plug and play! simple as that! I just wanna ride!
tstewartfn14 said:
You wont regret it. Rock is the best at customer service I have ever dealt with.
X2!!!!!
