number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I would love to see some feedback now that both TD and Hurricane have had stock muffler flashes out for a full season. If you ran a stock muffler flash this winter, please post your thoughts, fuel mileage, and any issues you had related to the tune.
DO NOT TURN THIS INTO A TD VS. HURRICANE THREAD. I do not care why you picked TD or Hurricane. I just want to see real world feedback.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Low and mid range was better but slowed top end down 8 MPH Don't check MPG. When i got the tune done that's when the oil leaks started.
viperjeff
- Apr 10, 2014
- clam falls wi
- 1999 sx 700(traded)
2006 apex gt(traded)
2011 nytro xtx
2015 viper mtx 153 mpi turbo ordered
Hurricane 225/240/270 ran flawless 1000 miles didn't check mileage
BTP
- Jan 5, 2018
- Michigan
- 2018 Thundercat, 2019 Thundercat
I'm interested in these as well for my trail rig. I just want a simple lower power upgrade that spools faster.
geez150
Oil leak from where? And what HP tune?Low and mid range was better but slowed top end down 8 MPH Don't check MPG. When i got the tune done that's when the oil leaks started.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Chain case and oil tank, 240 tune.Oil leak from where? And what HP tune?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
TD Max Spool 16, 3 bar tune with BOV and 22 top gear.
Huge difference from stock, power wise, and does not hurt the mpg at all. Same tune for stock or modded exhaust.
Just went on another last ride of the season, so 2600 miles this season on this above stated tune. Not 1 problem with anything on whole sled. Just gas and go type year besides the usual checks on rollers, track, etc.
Usually run 93 if available but also used 91 and the 90 non-ethanol. Yes long WOT runs.
Tempted to try 89 whereas have never seen the knock light on this 3 bar tune.
This tune is very powerful for trails and every bit of throttle makes a difference.
I like just over or under 9000 rpm with this tune.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Same here. I ride really twisty trails. Rarely go over 100. I find the throttle response and low end power to be lacking with the stock tune.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
TD stock muffler jukebox for 2 years. The flash to pass button and flasher are a little flaky. Because of that, most of my riding this past year was on Ecotrail. I estimate 14-16 mpg. I rarely track it anymore. During this past season only a 600 etec in our group ever used less gas than me. Im going to single flash my sled to Max Spool 16 and leave it.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hurricane stock muffler tune bundle worked flawlessly all season over 3000km
I tuned my 19 at 0 km.
If you do a stock muffler tune I suggest to add Bov, and 3 bar map sensor. I run just the tune at first then add Bov ,3 bar and cai and it mad a good difference. I run the #*$&@ out of my sled this season!! Mostly on 270 or 240 when riding with wife I would run 225
I recently bought the hurricane trail muffler and changed tunes to 240 270 300hp to compare!!
Aftermarket muffler tune definitely spools up turbo faster it Hits like a freight train ..lol
Nice thing with the hurricane trail muffler it is just as quiet as stock just more of a growl and you can rivet the stock muffler stamped cover to the muffler for a total stock looking muffler
On my 19 ltx, the left portion of my shock adjust button changes the tunes on the go.TD stock muffler jukebox for 2 years. The flash to pass button and flasher are a little flaky. Because of that, most of my riding this past year was on Ecotrail. I estimate 14-16 mpg. I rarely track it anymore. During this past season only a 600 etec in our group ever used less gas than me. Im going to single flash my sled to Max Spool 16 and leave it.
TD tunes.
All flawless performance.
I flashed many others also.
Zero issues.
actionjack
- Apr 9, 2005
Dash flash correct? Does the flasher stay connnected?On my 19 ltx, the left portion of my shock adjust button changes the tunes on the go.
TD tunes.
Zero issues.
Yes and noDash flash correct? Does the flasher stay connnected?
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
If you don't mind me asking, why did you ride most of the season on Ecotrail when you had Max16 in the bundle? I am curious how big of a difference there is between Eco SM, PT SM, and MS16.
actionjack
- Apr 9, 2005
Eco is default. Connection to flasher and phone was buggy and after restart it would be back to Eco. Sometimes the data screen would just freeze. I got tired of trying to make the flasher connection and just drove it. Sled spent winter in Maine hundreds of miles away. I need to update my flasher and try to reflash to single tune and only use datalogging when think I need it. IMO each step is a noticeable difference - I have no data to back it up (there are more than enough endorsements here of the Max Spool tunes). I'm curious but I have no real need for a TD GPS. If money is a concern go for the biggest single tune for the equipment you are going to run. For me that means factory muffler, 3 bar sensor and Turbosmart BOV - SM MS 16. Maybe I'll dash flash - this is my favorite money pit after all.If you don't mind me asking, why did you ride most of the season on Ecotrail when you had Max16 in the bundle? I am curious how big of a difference there is between Eco SM, PT SM, and MS16.
