rfabro
Mtnviper said:One thing to add, the 150 hp phazer is going to require race fuel. Or at least a 50/50 mix. The Nytro at 130 hp will run on reg fuel.
Bill
BS! The MCX kit gives the Phazer 150HP on 91 octane pump gas at 12psi at sea level. This kit has a built-in boost controller and barometer. So at 6000 feet, you'll get the same power as at sea level. You will just be boosting 14psi instead. If you want more power/boost, THEN you need avgas or race fuel.
