Ti3m
- Jan 20, 2015
- Sandpoint, Idaho
- Phazer FX 2007
I have a 2007 Phazer with a 141 x 14 track. What is the pitch of a Yamaha track? What aftermarket track is best for off trail use? I think it has a 1.75" paddle now measured from the flat outside surface to the top of the paddle...
MikeWalters
If its a Phazer MTX you will have a 144". 2.52 pitch. Also there was no option for a 1.75" track. Just a 2" Maverick. Maybe you already have something aftermarket. Off trail a 144x1.75" would be dynamite.
Are you sure on the 141 or not? Its not impossible but would mean someone changed the track, drivers and skid.
Ti3m
- Jan 20, 2015
- Sandpoint, Idaho
- Phazer FX 2007
No I'm not sure... What was the stock track on the 2007 Phazer FX?
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
The oem track on an FX is 121x14x1 Camoplast Ripsaw.
http://www.yamahamotorsports.com/sport/models/phazer-fx/features
Ti3m
- Jan 20, 2015
- Sandpoint, Idaho
- Phazer FX 2007
The track that is on it is a Yamaha 8GP 47110 00. Does anyone know the size and what is a suitable replacement? It looks longer than a 121 but I couldn't say for certain.The oem track on an FX is 121x14x1 Camoplast Ripsaw.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
That is a stock 144 MTX track. Not a FX.
As for replacement, are you mainly mountain riding or trail?
ATV PRO #11
- Jan 22, 2011
Hey Ti3m, post a pic of your machine. that'll, i'm sure help.
Ti3m
- Jan 20, 2015
- Sandpoint, Idaho
- Phazer FX 2007
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
That's an 07 MTX, I think officially called a Mountian Light for that one year only.
The FX sticker on the sled refers to the chassis. They did also make a model called and FX in 07 that was a 121 but he name was changed to the RTX in 08, I think to avoid the confusion.
MikeWalters
Yeah looks like the stock 2" track. A bit much for cross country, and the lugs are fairly soft. If you want a real crossover track you would have to to a 144x14x1.75". Like the newer Phazer XTX has.
Or just run what you have and see if you like it. Other option is to get a a regular 15" wide track 144x1.75 or 1.5 and trim the track down on the sides with a table saw. LOTS have done it. Fairly easy to do and track is reliable when trimmed down.
Ti3m
- Jan 20, 2015
- Sandpoint, Idaho
- Phazer FX 2007
The track is pretty chewed up now. I'll start looking for a 144 x 14 x 1.75 with 2.52 pitch.
Thanks again!
Thanks again!
MikeWalters
You wont find that track without cutting it, my mistake I think the newer XTX is a 144 x 14 x 1.5
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
They used to make a 144 Freeride which was 14 X 1.5. but I'm not sure if it is made anymore.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I've run both the Stock Maverick, and the 144" Freeride. The ONLY place the Maverick was slightly better was really fluffy light powder, the Freeride is far superior on anything else and it the only direct replacement track available. Its a STIFF lug 1.5" lug track with a good mix of paddles and fingers. As others have said, any 144x15 track will work if you have access to a decent table saw and trim 1/2" off each side.
