Anthonynytro
- Mar 2, 2021
- 2009 Yamaha nytro xtx
2007 Yamaha Phazer GT
Noticed alot of newer sleds with Their A arms straight or parallel to the ground.
The previous suspension setup on my Nytro XTX was front springs with very little preload (high front end)
Center shock very hard preload
Transfer rods maxed
Limited strap 1 tighter from stock.
Currently trying this setup:
-Lowered front to make A arms straight
- center shock preload loose or just making contact with spring
-limiter strap stock location
I haven't ridden the sled yet to see what the changes have done but wondering what everyone else has done with there setup
I weigh around 220lbs
The sled was previously pushing in corners and having bad weight transfer issues
Also track is not studded
Transfer rods maxed
Anthonynytro
- Mar 2, 2021
it will corner flatter and take more input to make wheelie over how it was. basically that is how my 11 apex xtx is set up and i love it.
