RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I have 1 bent rail on my apex.
it is bent up directly between the 2 front wheels.
Not too badly bent. It actually took me a few times looking at it to notice it was bent. If u put a straight edge across it there is about a 3/16 gap between the rail and the straight edge at the deepest part of the bend.
I dont want to use it as it is. I was thinking about trying to straighten it out in a press. If i screw it up i need to buy a new rail anyway since i am not going to use it. Anyone ever straighten one of these with any luck???
If you did, did it hold up??
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I did one on a RX-1 i had it work till i hit some big bumps. You should bolt something to the rail to make it stronger after you fix it good luck
NY AttakGT
You can bend it back to shape, but once the metal bends, it is not as strong as it once was at the flex point/s. So like the other guy says, some sort of rigid, metal support brace (along where is was bent) is a good idea.
--Steeve (O.C)
--Steeve (O.C)
copo427ss
replace it. you dont wanna bend aluminum back.
Iceman57
I agree to replace it.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
going to replace it.
sounds like it might end up being a problem if i dont.
thanks for the input guys
