RX1Jim
Guys,
When you change the oil on you sleds this season, it is a good idea to remove the outlet fitting at the bottom of the oil tank by unsrewing the two 6 mm dia. allen bolts. Once you take this oulet off you'll find a strainer screen that should be cleaned every 2-3 oil changes since it will accumulate crud on it which will impede the oil flow. The outlet has an o-ring on it so you don't have to worry about replacing a gasket.
