raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Well i think the nytro is going under the knife this winter for a stretch. Going with oft tip up extentions and 1.5 intense i think. Do the shocks need to be revalved? do the springs need to be changed?
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
raginyamaha said:Well i think the nytro is going under the knife this winter for a stretch. Going with oft tip up extentions and 1.5 intense i think. Do the shocks need to be revalved? do the springs need to be changed?
I would suggest adding some wheels at the back or you will burn sliders where the tip up is.
Are you already running your spring and shock near the stiff limit? If not I'd say give em a couple clicks and try that.
rage763
if im not mistaken, the Intense is only 121" and 136". what the website shows anyways
nytroman20
Pretty sure you can get the intense in 144" in royal distributing.
