pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
I have a 2010 nytro xtx. The front shock in the skid has some damage on the thread so trying to adjust the spring pressure is near impossible. Only 2 threads are stripped.Anyone ever had this repaired? is it possible? hoping i dont need to replace the shock.
Pstn head
You might have to remove the shock and work with it on the bench, a tiny file very gently through the threads where damaged could solve your problem or you might also be able to work the jam nut ever so slightly with some wd40 and challen lock pliers (pump pliers)
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Check this out it might be what you need to do to fix it. http://www.thumpertalk.com/topic/947311-shock-body-thread-repair/ scroll down alittle
good luck
Pete
good luck
Pete
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Ok thank you herndrop
Sent from my SM-G900W8 using Tapatalk
