studding a ripsaw
fx-treme
Massena NY ( Adirondack Mountain Area )
2014 SR VIPER LTX SE
i like the 06 line up but i would like to get into snocross with a yamaha 4 stroke.when will that happen.to the real question i have a 03 rx-1 le with a ripsaw track and would like to stud it but it seems i have 1/2 in. or less of clearence between the lugs and the front heat exchanger,and tunnel protectors. i can't fit my finger between either of them.what do i need to do to stud it without damaging anything and what size studs. :rocks:
Just studded my 05 RX1-ER with 1.325 Woody Signature Series SS. Have room but they do stick up quite abit. Go to Woody's home page and input your sled information and they will give you the right stud to use.
i have 192 extreme max 1.40 on woodys double backers all down the middle with no problem
I've got a 04 Rx-1 and used Woody's Golddiggers 1.325 144 of them in the center. No problems and plenty of room between the top of stud and exchanger. In fact there is more clearance between the HE and stud on the RX-1 then on my 02 Viper with the .92 lug track using 1 inch studs.
I just came back from the 06 preview and the Yamaha reps told me that there are no problems with studding RX-1's nor will there be any with the 06's but Yamaha the company does not want you to stud their sleds.
