dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
Looking to stud my wives RS Rage for braking and cornering safety. It also helps her keep up! Any size and/or pattern recommendations?
Don't want to go past 2 studs per section.
Attak44
I just finished studding my wife's LTX GT. I used the Woody's template with 1.375 studs. The pattern is the same as the 121 inch track with 96 studs, 2 per row. I did the same with her 05 Vector and it worked perfect. She only weighs 100lbs and tires quickly if the sled is hard to corner. I also put on slydogs with bergstrom 6" triple points and ski savers.
If your wife isn't looking to drag race, I think this would be a good set up.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
dsimonRX1 said:Don't want to go past 2 studs per section.
Thats perfect for what she needs. 2 per row. Also for skis go with a wider ski for better floatation. Will make it easyer to for her to steer, or go with stock skis and duallys.
Have you thought about an ice ripper track????? sounds like the perfect answer. I love the ice ripper, have on on my attak and wifes vector.
Safety Sean
Studs for your wives...no that one is too easy to put off the rails.
