bluemissile
so after years of no studs i have decided to run minimal studs on my sled the problem is what length and what are the favorites among the site. i have searched for this with no avail. it is a stock 06 nytro 1.25 ripsaw. 121 inch
bluemissile
i really surprised that there a zero comments on this.
boritzer1234
We got the simple Woody's golddiggers I believe. I put 96 down the middle because I dont believe in them on the outside. It helps a lot in the corners. We put 1.325 inch length on I believe.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I am running 1.325" Woodys Stainless Signature Series with their tall aluminum nuts down the center of my 1.25 Ripsaw on my Rage. After 3,000 miles they still look new with no bent studs or pull thru's. G.B.
burg226
- Jan 24, 2011
- Newcastle, ON CANADA
- 2017 Arctic Cat 9000RR
You could get by with running 96 1.325" studs up the middle. Works out to 2 studs per row of lugs. Studboy studs has a nice "V" pattern for this setup that works well.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
X2, 96 1.325" studs up the middle in a "V" pattern with aluminum backers. I have had a few pull thru however.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Gone Blue said:I am running 1.325" Woodys Stainless Signature Series with their tall aluminum nuts down the center of my 1.25 Ripsaw on my Rage. After 3,000 miles they still look new with no bent studs or pull thru's. G.B.
Mine are in a "V" pattern all up the middle with all double backers. Rock solid and no issues after 3,000 miles. The double backers give the studs and track all kinds of support. G.B.
