Choids454
This may sound like a stupid question, but does anyone know how to modify tunnel protectors? I'm installing a Powderlites Stage 2 on my 09 Nytro RTX (1.25 lug) and will be studding the track with 1.325 double backed studs. I've been in contact with Darren from Powderlites and he told me that in order to protect the turbo and the tubes, I would have to modify the portectors. Has anyone done this or know what to do??
Thanks in advance
Thanks in advance
Need for Speed 2
Add some plastic hyfax to the aluminum or ad longer bracing
Choids454
Need for Speed 2 said:Add some plastic hyfax to the aluminum or ad longer bracing
Thanks for the info, but how do you add hyfax to the protectors?? Do you rivet the hyfax?
yup just use a table saw to cut the hyfax flat and drill, line up the hyfax to the alum protectors and drill and rivet. I am in the middle of doing this as well
aj
aj
Choids454
aja636 said:yup just use a table saw to cut the hyfax flat and drill, line up the hyfax to the alum protectors and drill and rivet. I am in the middle of doing this as well
aj
Thanks AJ. Are you doing the front heat exchanger as well??
Choids454
aj
If it isn't too much to ask, would you be able to provide picts??
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Choids454 said:aja636 said:yup just use a table saw to cut the hyfax flat and drill, line up the hyfax to the alum protectors and drill and rivet. I am in the middle of doing this as well
aj
Choids454
Awesome!!!!
Thanks Ted I really appreciate it.
