farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
how should i store my 07 Phazer for summer storage?
rhino_live said:i drain my fuel system compleatly, run the machine till the lines are dry, keep a pallet or a couple old 2x4s under the track to keep the crap off of it (dirt floor in the shop). since i swap my plugs every fall i do nothing with them, then it's just a simple pull out my bettery and put it in my quad
haven't had any issues yet starting mine after she tapped out, as long as you give the throttle body some time to prime itself (couple turns on the starter) shouldn't have any issues, of course one could always spray starting fluid into the air filter but that just spells bad newslow slung said:I tought sleds with EFI were really hard to restart when you run them dry of fuel?
LMAO!Ruckus said:I completely dismantle mine and put into a series of small containers which I store in a germ and moisture free, environmentally sealed hypobaric chamber I have installed under the garage.
