mx1500
nope then i get a fresh clean engine every winter from yamaha. works every time (sarcastic)
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
lol good idea im going to try that!
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
oh crap i did it and now just rememberd i dont have warranty!!!!
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I drain the gas, add Seafoam, run the sled, take weight off front and back shocks, grease skid, spray lube on all bolts, and if I am energetic I take springs out of clutches.
mx1500
i got warranty till december 2011 so i hope we get snow in november then i can get a new engine
BombaPolaYama
Isn't it more about making the sled happy?4strokesmokextx said:whatever makes you happy go with it. Every one has a different idea of how to store their sled.
i just run stabilizer through the system and let it set till winter comes back around then get it ready.............
As for the fuel, it is recommended to also have a full tank of gas to reduce the moisture build-up. Grease is important in the bearings to force out the moisture. This is the first I have heard of changing the oil in the spring time.
Are there any thoughts (good or bad idea?) on starting it on a monthly basis and letting it warm until the red light goes off?
Loffy_09
- Jan 7, 2014
I also Own Nytro. Before putting it into storage in Tingalpa, I take clutches off, oil change, grease, and cover all metal parts to prevent corrosion.Because of the preventions that I took for my Nytro, it still looks brand new.
BombaPolaYama said:Isn't it more about making the sled happy?4strokesmokextx said:whatever makes you happy go with it. Every one has a different idea of how to store their sled.
Changing the oil before storage is a good idea. I do this w the boat, snowblower, lawnmower, etc.
- 7K
