Daniel Herting
Does anyone know how much boost yoy can put to a nytro using a super charger on a stock motor? Or the pully ration to the boost
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Im running 10 pounds of boost on my stage 1 MPI supercharger kit. 91 octane, stock ecu, did install an aftermarket high volume fuel pump and added MPI regulator to fuel rail. Approx 220hp !! Very nice to ride. MPI informed me this is max boost for 91 octane
Daniel Herting
What altitude are you running and what pullys do you have on sled. And we just installed the stock super charger system for low altitude with 26 tooth on bottom and 28 on bottomIm running 10 pounds of boost on my stage 1 MPI supercharger kit. 91 octane, stock ecu, did install an aftermarket high volume fuel pump and added MPI regulator to fuel rail. Approx 220hp !! Very nice to ride. MPI informed me this is max boost for 91 octane
Daniel Herting
Is the fuel rail and pump a necessary for that much boost?What altitude are you running and what pullys do you have on sled. And we just installed the stock super charger system for low altitude with 26 tooth on bottom and 28 on bottom
pro-man
- Aug 30, 2017
- Lwr Michigan
- vmax-sold
m.schuey7
- Feb 4, 2014
Im riding between 2500 and 5500 elevtion
- 7K
