supercharged nytro guys help
yamahacat69
alberta canada
2013 rtx mpi charger 6-7 pounds of boost do this clutching sound right 53/41 helix purple spring wraped at 0/1 ,,, blue silver blue in primary with supertips can i get some feedback please sled just dont feel like its pulling to me,,, thoughts thanks
At low elevation with the stage one kit, I run the b-s-b primary Spring, 1 Tungsten and 3 washers in the heel, 2 washers mid, and 3 washers in the tip. I have the Ulmer helix and use the stock spring.
(engagement is at about 3000 and runs out to 8900)
trouble im haveing is it hitting the rev limiter soon as i pull the trottle wide open i started 1 tungsten in the heel then with 2 tungsten in heel same thing while loading up the tip because it was goin over 9000,, the thing in the mid range just feels like a dog just dont make sence
How much do your weights weigh to start?
It was Ulmers Stage 2 kit from my previous Nytro...I'll try to remember to check tonight and let you know the whole setup.
thank you sir ,,, i think its around 67-68 grams im not 100% what i had in it that was last year i tryed a set of heavy hitters they worked better but i had to put some welding on them to get the sled to work , i am trying take them out go back to the supertips
