RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
hey guys
I know a lot of you guys must have your supercharged sleds up and running by now. how about a few reports???
problems with assembly, likes, dislikes. i am considering a supercharger and looking for any info. positive and negative
thanks..
thanks..
monker
no problems. no dislikes. about 500 miles and lovin every minute of it. I haven't been out since I got my clutching pretty much finalized.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
monker, did you do the install? if so how long and did it all go together as planned??
Silverbullet
I'll let you know as soon as I see some SNOW
Bossman
I second that Silverbullet. Hopefully next weekend I will have some news.
KbxSrx
I rode Revelstoke again today, 4th trip on the s/c and it ran flawlessly. I am pulling 1 lb off idle, 3 lbs at midrange 4000-7000 and 5-6 lbs WFO. Climbed good, I have installed a new skid and have to get it transferring, but the sc is was perfect today.
Next time I am going to try 10 lbs, see what that is like.
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
Had my 05 RX1 MPI SC out first time last weekend. 5 PSI at 3000 RPM
10 PSI at 6-7000 rpm 15 PSI at WOT I was attempting to trail ride so the
WOT part was never more than 1-3 seconds WAY TOO FAST for tight NY
trail with rocks/boulders/trees etc. Had some install related problems but
thanks to help from MPI all should be right for this coming weekend. I
am switching to 1 to 1 pulleys shooting for 10-12 PSI max boost-which should be plenty!! I had 1 brief chance on a lake- at 70MPH this thing will hang the skis a foot in the air-INSTANTANEOUS RESPONSE-this is with stock clutching and 96 stud-shorty
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
sounds great guys. i kinda figured we were not hearing too much yet because of the snow conditions
silverbullet bossman kbxsrx
did you guys do the install yourself??
if so how long and any problems??
millstreet
i have dealt with mpi in the past and always had good service.
what was the problem you ran into.
glad to hear they fixed it .
anyone have any dislikes about the kit???
millstreet
KbxSrx
Yes, 9 hours, no troubles.
MAKE SURE YOU READ THE INSTRUCTIONS.
Too many guys slap it in and run pump gas at 10 lbs, gonna cause troubles.
monker
leaderoftheback said:monker, did you do the install? if so how long and did it all go together as planned??
Yes, I did the install. Around 10 hours. Make sure you READ everything first and follow the steps. I tried to do things a little easier, but it usually came back to bite me in a later step.
millstreet
- Dec 6, 2005
millstreet
had the intercooler come off 3 times & had the upper pulley(driven pulley on jackshaft)on right side spin on the shaft both due to install problems
This time I'm doing it myself!!! Hats off to MPI great kit(it delivers as promised). Follow instructions carefully/take your time-it will be well worth the effort
whitee
just had my S/C rx 1 out today for the first time and I am loving it worked great need to do some clutching but 60mph track speed climbing at 9000 feet is a good start
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
thanks for the info guys!!
keep posting.
keep posting.
KbxSrx
Rode revy again, terrible visibility, but played in the trees, and had bad snow ingestion troubles, when the hood gets covered its game over. I am thinking a snorkle, have to do some modding. Anyone tried this? Oh yeah- we were in 4-5 feet of powder when we found some nice meadows to play in.
