Suspension Knocking on 2007 Attak?
kenbar
North-Eastern Canada
2007 Attak with 120 miles so far. When I go over big bumps there is a knocking sound coming from the track/suspension. I believe I read somewhere here that this is "normal" athough it sounds like something is loose and doesn't sound normal. Nothing obvious from a visual inspection. Any comments or anyone experience this?
Kenbar
Its the transfer rod. As the susp rocks it couples and makes the bang. Its normal as there is not a rubber cushion to dampen it.
They all so this, its the transfer rod. When you tighten the limiter it sucks the skid in more and reduces the noise.
