TAP BREATHER OIL SEPARATOR KIT
Ted Jannetty
Waterbury Ct.
Website
www.jannettyracing.com
I recieved a lot of requests for these so I decided to put them in to production.
Geared toward the RX1 Turbo/Supercharger and mounts on the steering column.
You Get Breather/ oil separator box, #12 hose, 2 Clamps, K&N Breather filter, rubber gromet, and 3/4 aluminum tubing, to weld on bottom of box in desired location.
We also can weld on the tube for you if you know where along the bottom of the box you want it.
I recommend Cutting the 90 degree fitting in the crank case so it points up Vertical for drainback.
Price is 99.95
Ted.
how does it bolt to the steering.just trying to get a idea of where to weld the tube on.
Thanks Benji, Exactly the reason I built my own 3 years ago I had a Northeat turbo kit and the LP would not work for me.
LP is a nice peice but I don't need 3 nipples only 1.
Ted.
I was not trying to hijack anything, just letting the consumer know there are some other brands out there for specific applications. Ted, you are saying it will work with superchargers too.
I know for a fact they work on MPI supercharged RX1
Ted.
