DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Just received my 3 bar map sensor and will be running Max Spool 17 this season. Any feedback from the guys that jumped from Max 17 to the quick spool tune? Big difference or what?
I just got the bundle of tunes and am going from PowerTrail to Max Spool 17 and wondering the same thing. Different tune and quick spool I get just curious as to the difference.
NYTurbo
Power trail to Max Spool 17 is a huge difference.
DMCTurbo
- Nov 12, 2005
What fuel you run with Max spool 17?
NYTurbo
Fresh 91.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Fresh 91.
Are you seeing the knock light at any time
NYTurbo
No
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
You want to carry torco with you for max spool 17 incase you get questionable fuel but it is an awesome tune it will 12 o’clock my BTX on the trail max 17 will not it definitely spools quick.
DMCTurbo
- Nov 12, 2005
Thanks if I get questionable fuel she'll be flashed down to ECOtrail. The benefits of having the ability to quickly change tunes via dash or gap app.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
It is awesome tech these aftermarket companies have out now I had knock lights flashing on max spool 17 and it was fresh 91 once so always keep an eye out for it.
DooZ
Where was that at? In WI we have problems with getting "good" 91 even tho everything is ethanol free.It is awesome tech these aftermarket companies have out now I had knock lights flashing on max spool 17 and it was fresh 91 once so always keep an eye out for it.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Munising MI and ethanol isnt really bad in this case it will lean it out a tad but ethonal has a high octane rating e85 is about 105 octane. But e85 takes 30percent more fuel. Ive ran 93 octane premium with ethonal and don’t have a problemWhere was that at? In WI we have problems with getting "good" 91 even tho everything is ethanol free.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
We have the same fuel that MN has.... All of the fuel coming into Northern WI is coming from MN.....
DooZ
That explains alot why it's no good...lol j/kWe have the same fuel that MN has.... All of the fuel coming into Northern WI is coming from MN.....
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
True....Ha
