rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Looking for honest opinion if it is worth going from pt cai to ms17. I am aware I will need a few things to step up and sure this has been discussed a million times before but gets of topic easy and the discussion is gone another direction. Looking for reviews from ppl that made the jump.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I started back in 2017 with powertrail then jumped into the tune bundle with all the tunes at my disposal. Going from PT to MS17 is 20 hp or 2 more lbs of boost which is a noticeable difference. Quicker spooling and arm stretching power. 91 octane safe. Boost is addicting! Once you run MS17 for a while you'll want MS20.
rev them up
- Apr 3, 2006
Thanks. How is the trail manners of ms17? Fuel milage comparable to pt if driven the same way.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I did not run MS 17 but ran Powertrail and eco.. I would think MS17 MIGHT be more sensitive to octane/fuel quality vs Powertrail.. Just a thought not any experience on MS17 yet.
DMCTurbo
- Nov 12, 2005
I didn't notice any difference in fuel mileage really. It all depends how hard you push the throttle. If riding normally I don't have any trouble getting 200kms on a tank.
rev them up
- Apr 3, 2006
Thanks. How did you find the ms17 on slower twisted trails...40/60mph. Have good trail manners? Realize alot of it is in the clutching (running full td kit)...I didn't notice any difference in fuel mileage really. It all depends how hard you push the throttle. If riding normally I don't have any trouble getting 200kms on a tank.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Watch center cylinder,???just saying 16 psi and under Is good.
rev them up
- Apr 3, 2006
Experience with this happening?Watch center cylinder,???just saying 16 psi and under Is good.
DMCTurbo
- Nov 12, 2005
What r u saying?Watch center cylinder,???just saying 16 psi and under Is good.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Ms17 is only tune I got, run 90-91 pump fuel no problems. Fuel mileage is very similar to stock. Power wise my arms hurt on 150+ mile days a bit as it does like to pull and you need to hold the reins. Otherwise she’s solid.
rev them up
- Apr 3, 2006
Thanks for the info!!Ms17 is only tune I got, run 90-91 pump fuel no problems. Fuel mileage is very similar to stock. Power wise my arms hurt on 150+ mile days a bit as it does like to pull and you need to hold the reins. Otherwise she’s solid.
