Td powertrail to max spool 17
Age
52
Prince Edward Island, Canada
Canada
2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
LOCATION
Looking for honest opinion if it is worth going from pt cai to ms17. I am aware I will need a few things to step up and sure this has been discussed a million times before but gets of topic easy and the discussion is gone another direction. Looking for reviews from ppl that made the jump.
I started back in 2017 with powertrail then jumped into the tune bundle with all the tunes at my disposal. Going from PT to MS17 is 20 hp or 2 more lbs of boost which is a noticeable difference. Quicker spooling and arm stretching power. 91 octane safe. Boost is addicting! Once you run MS17 for a while you'll want MS20.
Thanks. How is the trail manners of ms17? Fuel milage comparable to pt if driven the same way.
I did not run MS 17 but ran Powertrail and eco.. I would think MS17 MIGHT be more sensitive to octane/fuel quality vs Powertrail.. Just a thought not any experience on MS17 yet.
I didn't notice any difference in fuel mileage really. It all depends how hard you push the throttle. If riding normally I don't have any trouble getting 200kms on a tank.
Thanks. How did you find the ms17 on slower twisted trails...40/60mph. Have good trail manners? Realize alot of it is in the clutching (running full td kit)...
Watch center cylinder,???just saying 16 psi and under Is good.
Ms17 is only tune I got, run 90-91 pump fuel no problems. Fuel mileage is very similar to stock. Power wise my arms hurt on 150+ mile days a bit as it does like to pull and you need to hold the reins. Otherwise she’s solid.
Thanks for the info!!
