Tech Tip on Fox Floats
MrSled
Site Admin/CEO
Staff member
Schofield, WI
Website
www.totallyamaha.com
2020 Sidewinder SRX
This was posted on
Yamaha Facebook
TECH TIP: Fox FLOAT Front Shocks on the Apex SE The standard setting of Fox FLOAT shocks equipped on the Apex SE is 85 psi, but they’re widely adjustable to suit your style. When checking pressure or making adjustments, always ensure the suspension is off the ground and unloaded. You should adjust pressure in no more than 5 psi steps at a time until find the setting you like. Remember, changes in air temperature can affect pressure by up to 4 psi per 10°F.
