Tether Switch
hlmrx1
Manitoba
Guess I should have started a new post as the topic in the other was all over and I'm not getting any response. I hate to bring up this topic again and I know everyone says buy a closed system tether splice into the kill switch, well in haste I bought one from Royal distributing and it's circuit is open when the tether is on so I can't hook it up in series with the kill switch . This type would work well if I just needed to ground a wire to kill the engine, is there such a circuit on the RX1 motor that one of you guys have installed one of these on? Maybe I should just go and get the Artic Cat on and install that one in series with the kill switch, that's probably the simplest thing to do!!!! Opionions?
after slicing and dicing up the wires in the handle bar area... :o| :drink::o| trying to get an open one to work.
...go get the AC-closed tether and hook into the solid Brown wire. 8)
--Buster696--
