Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Knapp, I think Mobile 1 is an outstanding (low performance) oil. Meaning there are better choices when considering race application.Mobile1 is actually an extremely good oil. I have used it for years in my Euro Audi's and Mercedes vehicles. I used to do used oil analysis on them, but because of the extremely low wear metals using Mobile1 0-40, I quit doing it a while back. The 0-40 FS which I use in my cars, does shear to a 30 weight rather quickly, which isn't so bad as the HTHS is higher than any 30 weight, and I have been thinking about using Mobile1 0-40 in the 998 as well knowing it will shear down to a 30 weight rather quickly. Mobie1 always leaves my engine clean inside doing 10,000 mile drain intervals. I've had the valve covers off at 200,000 miles before to know.
For a guy who's just riding his sled around willy-nilly, it's perfect.
I'm thinking more along the lines of 300hp and continuous pulls, or long pulls for that matter on a lake.
I'm glad you enjoy that lake speed guy as well. Talk about breaking down an oil's ability lol. He does a pretty good job.
The other thing we always forget or at least I do, are the bearings in the turbo, again specially when boost is getting cranked up. A little extra protection doesn't hurt.
Enjoy the day, Knapp
Doc Harley
- Oct 17, 2016
- Here & there
More testing on two simular base products. This one seems to be very conclusive to the point he always tries to make.
Turboflash
- Mar 18, 2019
- Southern MN
I'm an advocate of gathering as much data/info as I can to make good decisions. I'm not in favor of, or against, any one motor oil "guru." Sometimes they conclude the same things, sometimes they don't. Each makes their case about how and why their data is best.Gave that a quick look and maybe a missed something.
Lake speed aka Motor Oil Geek shows results and includes data. He's extremely versatile, owns his own business analyzing oil, one of the guys that helped formulate the Joe Gibbs racing oil (Driven), a rep for Total Seal rings, etc.
He's totally in favor of the zddp product in the correct PPM.
Turbo, when you get a chance try to watch at least three YouTube videos that match your interest.
I'm almost positive you wouldn't come back here and find rebuttal comments to refute his findings.
Re: Gibbs - if you go to the Rat blog, do control F (or F3) the search function will come up. Type in Gibbs (for example) and it will highlight any references to Gibbs. Of the 300 oils Rat tested (by his means/methods) and ranked for wear protection, Gibbs oils were #78, 94, 173, and 293 in ranking.
I have visited lots of YouTube oil videos.
BTW - Rat does mention multiple places that ZDDP in the right % is fine and does reduce friction but one should not base an oil selection only on zinc %.
Doc Harley
- Oct 17, 2016
- Here & there
Agree & understood. We have to remember that zddp is poisonous to the catalytic converter (which we don't have)I'm an advocate of gathering as much data/info as I can to make good decisions. I'm not in favor of, or against, any one motor oil "guru." Sometimes they conclude the same things, sometimes they don't. Each makes their case about how and why their data is best.
The more I research the more I see a commonality of 800ppm & additive package. In my mind they are supplementing the zddp with a more aggressive additive package to protect that very expensive catalytic converter, while still being able to protect our engines critical parts.
But I also believe zddp is the main basis for protection.
In the end we can look at the data and form our own conclusions, on what's best.
And to the placement of Joe Gibbs racing oil in the rat blog, I have no idea how he comes to those conclusions, without data to support his claims. I thought it to be an older blog?
Case in point; Valvoline VR1 racing oil has a new & improved formula, that they didn't have two years ago.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Tribodyn and done lol.
Doc Harley
- Oct 17, 2016
- Here & there
Come on!! This topic is not about snake oil!! HahaTribodyn and done lol.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Direct from your 540 rat guy.
Like your non chemist YouTuber said the breakdown is just a chemical breakdown and not how it works in the least. Only reason he didn’t like it was because it was for some reason more money. However it’s much less for me to buy tribodyn than amsoil signature.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, to satisfy himself he posts a video of Base oil properties. It sure would have been nice if he posted after the fact videos.
I'm thinking our biggest problem is fuel dilution. Big boost, big pumps, etc. has me processing the thought of going to a 5/40 weight. But like all things I'll need to review more and more data to come to some conclusion.
