jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
I was innocently trail riding and after accidentally hammering the throttle to lift the skis (since I don't want to wear them out
I had a situation where Mr sled wanted to head for the bushes and buck me off. In a panic I was able to grab the handlebar from underneath on my way off the sled and coax it away from said trees. At that point I lost all power. Nothing. No lights in the display, no whir of fuel pumps when turning the key back on. There is a tether connected to the left side where I grabbed - if the wires leading to it were somehow disturbed would that cause said problem? Any other ideas?
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Pull up the kill switch on the right bar
Lman69
Guest
- Nov 5, 2013
Tether not connected properly and or wires not connected will cause problems. I had a worn out tether connecter that caused me problems till I replaced.
Sent from my SM-G930W8 using Tapatalk
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Lol.. kill switch is disabled anyway (I forgot to mention that, and figured that solution would come up). Thanks Lman. Are we talking 'complete lack of power' problems?
Lman69
Guest
- Nov 5, 2013
My tether is wired to kill switch wiring so yeah had no power till put new tether on. Carry extra one just in case I ever lose the main one. Swapped on trailer and boom back up and running.
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
I worried mine would be an issue on trail, so I put connectors on that I can pull the cowl, unsnap it, and re-connect it bypassing the tether until I get home. I got upset with it when I couldn't get it seated right in the warm fall with warm, ungloved hands. I could see how pissed off I was going to be on the Tug, in -20, fudging with the damn thing.
Lman69
Guest
- Nov 5, 2013
I've done the same as well just in case I can't get it working.
Lman69
Guest
- Nov 5, 2013
I also meant on trail and not trailer.
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
If I follow the wires back from the tether, there is a connection I can take apart and jump the wires. Having done this there is still no power - does this rule the tether out, or would I need to replace the tether itself to know?
- 6K
