SRX Boy
I’m playing with the Sledzilla gearing app which allows you to play with the variables that produce theoretical max speed. Can someone help me with a couple of the key inputs for the 137” Sidewinder??
Max tech RPM: think that is 8900
Num of drive teeth: ??
Clutch gear reduction: think this is 1.0 for Sidewinder??
Clutch Ratio: not sure?? - app says for non-overdrive use 1.0 for overdrive yamaha use .9
Top sprocket: think stock is 21
Bottom sprocket: ??
Track pitch: 2.52
Bottom sprocket: ??
Track pitch: 2.52
sledding rocks
9 toothI’m playing with the Sledzilla gearing app which allows you to play with the variables that produce theoretical max speed. Can someone help me with a couple of the key inputs for the 137” Sidewinder??
Bottom sprocket: ??
Track pitch: 2.52
.95 clutch ratio
bottom 41
track pitch 2.86
SRX Boy
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
My cousins BTX LE went 118mph witb 24/50 gearing that’s 17% overdrive!
Byam
Od "real world". .93
120mph gps is pretty much the top it can go "stock"
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Yes that was on max 17 TD tune and with 21/41 gears 122mph and it’s had more in it
Byam
Stock sheave?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Yup stock clutches no machining idk how it’s possible but it does it my btx is a few mph slower both sleds the belts bottoms out and rubs the secondary
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
126gps has been posted before.....21/41, Obviously need the HP and conditions to get it there too.
22 top gear can tap over 130gps.
Dan
Dan
